  • 1.  API and colordiffuse
    Posted 05-13-2012 18:36
    Hi everyone,
    I have an existing material with a B/W image and I have to colorize it (with RGB) by API.
    I saw the colordiffuse property, but it's an read-only one.
    Does anyone know how can I do ?
    Thanks !
  • 2.  RE: API and colordiffuse
    Posted 05-13-2012 19:14
    You can read the Color Diffuse property from the material and assign it to a Color object. Once you have the color object you can access the .R .G and .B properties of it (those properties are read/write)
  • 3.  RE: API and colordiffuse
    Posted 05-13-2012 19:58
    I don't really understand.
    At the beginning, my material has a white colorDiffuse and image inside is W/B (imagine a box). So by applying a color (ie blue 0,0,200), my box will appear blue.
    You give me another way to have the same result, but I don't see how to access it.
    Could you explain it ? How my xpColor wil interact to my specific material ?
    Thank you.
  • 4.  RE: API and colordiffuse
    Posted 05-14-2012 01:37
    Maybe I'm not understanding what you're asking; but don't you just need to do this?
    dim mat as xpMaterial
    dim color as xpColor
    engine.GetMaterialByName("material1", mat)
    color = mat.colorDiffuse
    color.R = 0
    color.G = 0
    color.B = 200
  • 5.  RE: API and colordiffuse
    Posted 05-14-2012 19:04
    It works like a charm, thank you !
