  • 1.  Data Page Transitions
    Posted 10-18-2013 15:32
    When I try to change the text on an on-air super from a scene set up as a data page, the on-air text will only cut from the old text to the new text. I would like it to dissolve. How do I do this?
  • 2.  RE: Data Page Transitions
    Posted 10-23-2013 15:35
    Anybody?
  • 3.  RE: Data Page Transitions
    Posted 10-23-2013 17:28
    The data pages currently only support a cut. However, you could use scripting to achieve a dissolve.
    I have created a sample for you:
    https://na11.springcm.com/atlas/Link/Document/12442/9460e363-083c-e311-a16d-d89d67143433/da78e46f-083c-e311-a16d-d89d67143433
  • 4.  RE: Data Page Transitions
    Posted 10-23-2013 20:58
    I just noticed that when you put the scene online for the first time, it runs the script/animation. I'll see if I can find a different way to accomplish this..
  • 5.  RE: Data Page Transitions
    Posted 10-23-2013 21:00
    I just updated the link above to include a fix for the issue I noted.. All should work ok now.
  • 6.  RE: Data Page Transitions
    Posted 12-12-2013 11:28
    Is the above information still available? I have exactly the same question!!
  • 7.  RE: Data Page Transitions
  • 8.  RE: Data Page Transitions
    Posted 12-13-2013 08:53
    Thanks for that Brian, will give it a go tomorrow! :)
