  • 1.  Assigning a font to a textobject
    Posted 03-15-2012 11:07
    I would like to do a stupid thing by API : Change the font (wich already exist in my project) of a textobject.
    Actually, I'm doing that :
    Dim fontrouge As New XPression.xpFont
    Dim Cagnotte As New XPression.xpTextObject
    Engine.GetFontByName("Cagnotte_en_jeu_neg", fontrouge)
    Scene.GetObjectByName("Cagnotte", Cagnotte)
    Cagnotte.CurrentFont = fontrouge
    MsgBox(Cagnotte.CurrentFont.Name)
    But this not works, currentfont.name is always returning my old font name before assignement.
    Thank you.
  • 2.  RE: Assigning a font to a textobject
    Posted 03-15-2012 14:09
    No matter, I find the pb...
    You have to do Cagnotte.Text = "", then assign font, and put in your value again...
    But whyyy ?! ;)
  • 3.  RE: Assigning a font to a textobject
    Posted 03-16-2012 18:38
    Hi Vincent, when replace a font for text in an object you must first capture the existing text in a temporary variable and then "empty" the text in the object, set your new font and then "paste" the text back in the object.
    Here is an example of how to change the font:
    'Define temp text container
    Dim strTemp As String
    'Define a text object
    Dim TextObj As xpTextObject
    'Define Font object
    Dim FontObj As xpFont
    ' ************* FONT COLOUR CHANGE ****************************
    'Get the text object you want to change colour
    self.GetObjectByName("text", TextObj)
    'Capture current text
    strTemp = TextObj.Text
    'Get New font defined
    Engine.GetFontByName("fontrouge", FontObj)
    'Clear text in text object
    TextObj.Text = ""
    'Set new font on text object
    TextObj.CurrentFont = FontObj
    'Re-enter text in textobject
    TextObj.Text = strTemp
    'end of code
    Regards
    Jim
