  • 1.  Visual Logic Reference Guide
    Posted 07-10-2018 18:02
    I understand half of the visual logic just by instinct. But half of it remains a mystery. Where is the reference guide to visual logic?
    I got problems, keeping a text box within a certain size. I can fix the width in the standard interface but I can't limit the height. I hope visual logic can help me but setting text box heights and such have failed so far: nothing happens.
  • 2.  RE: Visual Logic Reference Guide
  • 3.  RE: Visual Logic Reference Guide
    Posted 07-10-2018 18:24
    You'll find explanations of the blocks in : Start Menu > XPression > Help > XPression Help > How To > Visual Logic
    And you'll find the guide on using visual logic in the XPression User Guide: https://rossvideoltd.sharepoint.com/:b:/s/marketing/Ee3u3riY9ytFuMqXAwmxciIB9UfhVJUL8Kz0aNROKswSng?e=MLu8Bg
  • 4.  RE: Visual Logic Reference Guide
    Posted 07-11-2018 09:26
    Thanks dberry, I found those videos before but still nice of you to post them again.
    Thanks garner. There are some problems: I do know the simple things as mentioned in the User Guide. I need the explanation of the building blocks! Alas, I have the 6.2 version in which the help file has no visual logic section. I am not allowed to upgrade from 6.2 as our computer department fears for control room incompatibility. Can you PLEASE send me a newer help file?
  • 5.  RE: Visual Logic Reference Guide
    Posted 07-11-2018 15:41
    Well I was sent the Help file by another user but it also only tells you how to throw blocks around and connect them and so on. The simple stuff. I REALLY need explanations of the more complex blocks. High time for a Visual Logic Reference Guide.
