All results in visual logic ends up beeing zero (0)
  • 1.  All results in visual logic ends up beeing zero (0)
    Posted 08-10-2016 11:07
    Solved - Pressed f12 to activate the viewport
  • 2.  RE: All results in visual logic ends up beeing zero (0)
    Posted 08-10-2016 13:05
    Please don't modify your message, just explain what you do to solve problems in order to help other members in same case...
