  • 1.  manual used for Xpression video coder
    Posted 06-12-2013 16:21
    Hi all
    i want a manual used for Xpression video coder because i don't known how to convert a file .tga
    p/s:i want convert file .tga to video .avi .Because file .tga when add to xpression it display as a picture not like a video.
    Thank all
  • 2.  RE: manual used for Xpression video coder
    Posted 06-12-2013 17:02
    Hello Lee,
    It is not very difficult.
    In the Videocoder go to New Job, select the first file of the .tga-sequence.
    Next select the Alpha Handling and change it to Shaped / Premultiplied (if applicable)
    Next in the Output-window select your desired Framerate and Field Mode and in Color depth choose RGB + Alpha.
    Select the location where you would like to store your .AVI-file and press the Render All button.
    It should start rendering.
    A big remark however on the .tga-sequence:
    Make sure the first file of the sequence starts with a 0 and that there are at least 3 digits in the filename.
    So for example: NameOfTheTgaSequence_0000.tga, NameOfTheTgaSequence_0001.tga, NameOfTheTgaSequence_0002.tga, etc...
    In some cases the sequence won't get properly rendered if the first file isn't 0 at the end.
    Good luck!
    Kenneth
