Hey all,
I know this is probably going to be a simple solution but it isn't coming to me so I thought I'd come here.
Basically, I am making a timer for a sports package. Once the clock hits a certain time, I need it to change colour. I have 2 versions of the text, one in yellow and one in red. When the timer reaches the desired time, the red text should become visible.
So far I have simply been trying to connect the text from my clock 1, into a greater than block (with 10 as the value) and then that makes clock 2 visible.
This isn't working however because the value coming from clock 1 isn't formatted in the same way (it's reading 00:10 instead). Is there a simple way to change the value into a solid number?
Hope that all made sense,
cheers
