  • 1.  Can you Keyframe effects in Xpression 5.0?
    Posted 07-22-2013 19:31
    Just upgraded to 5.0 and was checking out the new effects. Is it possible to keyframe the attributes of the effects?
  • 2.  RE: Can you Keyframe effects in Xpression 5.0?
    Posted 07-22-2013 21:25
    Hi Jesse.
    It is currently not possible but I would expect this will be available in a future release.
  • 3.  RE: Can you Keyframe effects in Xpression 5.0?
    Posted 09-09-2015 12:25
    Is it possible to keyframe the effects in v6?
  • 4.  RE: Can you Keyframe effects in Xpression 5.0?
    Posted 09-09-2015 14:43
    Not directly but you can keyframe a (hidden) object in the scene and use visual logic to link a property from the object to a property on the effect..
    e.g. Animating the X Center of the LightRays effect:
  • 5.  RE: Can you Keyframe effects in Xpression 5.0?
    Posted 09-10-2015 06:56
    Thanks Brian,
    I had to keyframe the "Box Mask" effect, and I solved it by setting the length of the effect to 1 frame, then adding 10 copies of the effect, and then changing the values for each frame :)
