Hi
If I wanted to have an object drop down in the middle of 3D space as if appearing from no-where, how can you do this without using a layer object with a mask? If I use a layer object as I would in a 2D scene, I get the desired effect, but if I have the wrong camera angle, everything in the layer object can get keyed over the top of everything else regardless of it's Z position.
Simon
