  • 1.  Largest available memory block size
    Posted 01-17-2018 13:19
    In the logs of our XPression system I see many log-lines like this one:
    Largest available memory block size: 1,838 GB
    Is this an indication the program is running with to litle memory?
    And if so, how to resolve?
    Regards,
    Barend Mondt
  • 2.  RE: Largest available memory block size
    Posted 01-17-2018 14:12
    No, it simply logs that every one minute for diagnostic purposes when Tech Support needs to troubleshoot problems.
    1,838GB is a very large amount of free memory. You only need to worry if that number starts to go below 300MB or so..
    There is a memory meter in the main UI of XPression next to the performance meter. If it does not approach 100%, you don't have anything to worry about.
