  • 1.  Strange Transition Logic Issue
    Posted 06-29-2018 10:07
    Hey everyone,
    I've just got back into using Xpression after a short break and am encountering a problem I've not found before. I am setting back to back settings with conditions for changing the top and bottom line of text. So I've done the whole, check top line is same, check bottom line is different etc.
    The issue is when I have then set the animations in the back to back settings, I cant set individual ones for the top and the bottom. So when I set the animations as Top Line In and Top Line Out, it changes the bottom animations to be the same.
    Hope this makes sense? Was a struggle to explain
  • 2.  RE: Strange Transition Logic Issue
    Posted 06-29-2018 10:35
    This was a bug fixed a while ago. You must be running an old version. Contact Tech support about upgrading.
  • 3.  RE: Strange Transition Logic Issue
    Posted 06-29-2018 12:51
    It was fixed in: version 7.1 build 3923 and higher.
