  • 1.  Xpression Clock DVE help
    Posted 12-07-2016 21:55
    Looking to DVE an external HD clock aimed at the game clock in basketball. I can get the signal into Xpression via the hardware, no problem. But i need to resize and mask the clock to fit inside the proper area of the graphic. Any help would be appreciated. And I would like to invert the signal so the clock is actually black over a white/grey background.
  • 2.  RE: Xpression Clock DVE help
    Posted 12-09-2016 00:07
    What version of XPression are you using? If you have XPression Prime, then you can't resize it. You can though with other editions.
