- You can use C++, C# and other languages too. It doesn't have to be Visual Basic.
- The Bluebox library is not available as a separate download from the website but if you have Xpression installed on your machine, you most likely can find the library under C:Program Files (x86)XPressionStudionet
- I always use the applications directly on the BlueBox or Studio machines. But I think there might be a way to control it from another pc. But I've never done it before and I don't really know how to get that done.
There are however some interface-protocols included in Xpression which might make it a bit easier such as the CII-gateway.
Best regards,
Kenneth
