  • 1.  exporting package - keeps asking for password
    Posted 09-19-2012 23:59
    i have used a wireframegroup template and modified to meet my needs. I used the Export Package command under the file menu but when I try to open on the real machine Iit asks for a password and then says its wrong. I have given it one- not given it one- used the one i got with the templates- all with no luck.
    Am i doing something wrong?
  • 2.  RE: exporting package - keeps asking for password
    Posted 09-20-2012 15:28
    If the xpp file didn't copy completely or got corrupted during the copy then it will think it is password protected. Make sure the file size is correct. Can you open the XPP package on the machine that created it?
    If all else fails; send it to Ross Tech Support and have them take a look at it.
  • 3.  RE: exporting package - keeps asking for password
    Posted 09-20-2012 15:47
    wow you are good- tried exporting again. closed everything. started program and opened file and it worked. tried loading onto laptop and it worked too...
