Drew, I would appreciate that. Ours is slightly different. The boss wants us to go into a 3d stage with back walls, and a floor with a 3d sponsor logo floating in the center. Imagine a turntable as the floor, and two flattened cubes that form an x dividing the floor into 4 rooms. Our operator has to be able to drag the correct scenes that will seamlessly transition to each other by way of rotating the turntable 90 degrees. However these scenes need to be easily located, and simply dragged over to the Sequencer because things change quickly. Our game rundowns are pretty fluid. I have gotten past the scene to scene trigger thanks to Garner at Ross. We just want to dress up the scene a bit with cool shadows. But I do like the idea of using Xpression as a playback engine for the 3d scenes.
