  • 1.  Graphic leaves black impression when taken off screen.
    Posted 08-17-2018 11:52
    I put a logo onto the screen.
    When we test it manually and take it off line, everything works fine.
    When we use the automation gateway to take the scene off line, a graphic shaped black spot in still visible.
    How can this be?
    (It is an HD project, amidst HD projects, but normally HD works fine in an SD system.)
  • 2.  RE: Graphic leaves black impression when taken off screen.
    Posted 08-17-2018 13:17
    My guess is that the key is still online. How are you taking the scene offline?
