  • 1.  Basic scripting help - show/hide object based on datalinq value
    Posted 06-12-2013 23:45
    Hi there. I'm fairly new to Xpression and am having a heck of a time trying to learn how to do some basic scripting (especially with the lack of examples/documentation).
    I have a hidden datalinq text object that automatically updates with a value of 0 or 1. If it's 1, I want to make a separate image object visible, if the value is 0, the object should be hidden.
    This is the code I'm trying, in OnSetText...
    if Text = 1 then
    Scene.SampleObject.visible = true
    else
    Scene.SampleObject.visible = false
    end if
    Any help would be appreciated! Thanks.
  • 2.  RE: Basic scripting help - show/hide object based on datalinq value
    Posted 06-13-2013 15:25
    First, I would do this at the scene level. I've just had better results. Then I would run it at the OnOnline, OnRender, and onPreviewRender. Since you're not just dealing with text, but with object visibility.
    Then try this code:
    dim txt as xpTextObject
    dim obj as xpBaseObject
    self.GetObjectByName("Your Text Object's Name", txt)
    self.GetObjectByName("Your Object's Name", obj)
    if txt.text = 1 then
    obj.visible = true
    elseif txt.text = 0 then
    obj.visible = false
    end if
    Since your values are known, you should specify by using elseif instead of else. If your text could be anything, but only if it was "1" you wanted something visible, then I would say to do that the other way.
    Another method I've had success with is using InStr, or "In String." This function returns the number of characters within $A that $B falls at. For example, if
    $A=abcdefg
    InStr($A, "b") would return 2
    InStr($A, "d") would return 4
    etc...
    I would use this:
    if InStr(txt.Text, "1") = 1 then
    obj.visible = True
    else
    obj.visible = False
    end if
    That would say "if the first character in your text is 1, then make it visible, otherwise hide it."
  • 3.  RE: Basic scripting help - show/hide object based on datalinq value
    Posted 06-13-2013 17:26
    Thanks Dan... that'll put me in the right direction.
  • 4.  RE: Basic scripting help - show/hide object based on datalinq value
    Posted 06-13-2013 20:18
    In addition to all the comments Dan made, I don't think you can do "if txt.text = 1".. you probably need the 1 in quotation marks like if txt.text = "1" because you are trying to compare two strings..
  • 5.  RE: Basic scripting help - show/hide object based on datalinq value
    Posted 06-13-2013 21:05
    Thanks. The code above worked perfectly. Curiously it did indeed work without having to put the value in quotation marks.
  • 6.  RE: Basic scripting help - show/hide object based on datalinq value
    Posted 06-13-2013 21:07
    It worked because it saw "1" as a string since we were comparing it to a .Text. If we were comparing to to an integer, it would have been confused, as it would have been going up against a string. This is just comparing two strings to each other to see if they are the same.
