If Datalinq returns empty on null then set text to 0
  • 1.  If Datalinq returns empty on null then set text to 0
    Posted 03-06-2018 17:14
    Is there a script or visual logic function to set the empty text object to 0 if the value is null? We display stats for AVG, HR, & RBI and the stat file outputs empty when there is no data. I'd like to change to the empty value to 0.
  • 2.  RE: If Datalinq returns empty on null then set text to 0
    Posted 03-06-2018 17:39
    You can use something like this.
    if text = Nothing then
    text = "0"
    End If
  • 3.  RE: If Datalinq returns empty on null then set text to 0
    Posted 03-06-2018 18:15
    Thank you
