Hi all,
I'm trying to get a frame from the first output framebuffer and use that as a material for a quad in a different scene on a second output, using the code below. I thought I had it figured out, but the GetCurrentFrame-function returns False for some reason (and L_xImage is nil). I used xpScene.GetRenderedFrame before successfully, so I guess I don't have to create the xpImage-object. Therefor I can only assume that the dimensions are incorrect, but how can that be: I use the dimensions of the framebuffer itself.
Note 1: I use Virtual Outputs; maybe that has some effect on the dimensions, but using hardcoded 1024x576 and 720x576 (it's an SD PAL project) didn't work either.
Note 2: I use Delphi, so the code is somewhat different to .NET, but the basic XPression-control is similar.
if G_xEngine.GetOutputFrameBuffer(0, L_xOutputFrameBuffer) then begin
if L_xOutputFrameBuffer.GetCurrentFrame(L_xOutputFrameBuffer.FrameWidth, L_xOutputFrameBuffer.FrameHeight, L_xImage) then begin
if glob_xEngine.MaterialExistsByName('Material1') then begin
if glob_xEngine.GetMaterialByName('Material1', L_xMaterial) then begin
if L_xMaterial.ShaderExistsByName('APITexture') then begin
if L_xMaterial.GetShaderByName('APITexture', L_xBaseShader) then begin
(L_xBaseShader as xpAPITextureShader).SetImageData(L_xImage, idt_ARGB);
end;
end;
end;
end;
end;
end;
Kind regards,
Gerard
