  • 1.  Transition Effect "“ OUT "” not working propely
    Posted 02-28-2012 02:09
    I've set up some graphics with Transition IN effects and they are working quite nicely, sort-of. However, the Transition OUT effect doesn't seem to be working properly. (or I've set it up wrong).
    When the effect (such as a push or wipe) comes IN, the video goes black as the transition moves across the screen. When the transition goes OUT, the video then flickers badly, like a noisy feed is trying to come in. I have to take another item (blank or with content) before it stops. The time it doesn't happen is when the transition is a cut. What am I missing here?
  • 2.  RE: Transition Effect "“ OUT "” not working propely
    Posted 02-28-2012 08:12
    The only time I have seen this happen was when the performance of XPression exceeded the 100%. Could this be the case?
  • 3.  RE: Transition Effect "“ OUT "” not working propely
    Posted 02-28-2012 14:26
    Hmm - good point. Thanks.
