  • 1.  Exporting Datalinq pages as images
    Posted 11-13-2013 16:40
    Hello All, this is a 2-part question... I have numerous Datalinq pages in my sequencer, I would like to be able to take a page that has the correct datalinq info on it and then unlink it but keep the same data. When I "Unlink" the field (using the sequencer) the data reverts to the template default. Is there a way to keep datalinq info, so I can export as JPG.
    Also, when I try to export multiple pages from the sequencer (that are datalinq) as JPG format. I will get multiple JPGs of the #1 page that is Datalinq. This does not happen on pages that are not datalinq.
  • 2.  RE: Exporting Datalinq pages as images
    Posted 12-23-2013 19:40
    Has there been any solution to this? I also experience the exporting images glitch where what saves is not what you see in the preview window for datalinq'd messages.
  • 3.  RE: Exporting Datalinq pages as images
    Posted 12-29-2013 07:26
    Hey Chris, on my end I solved it by selecting the last frame of the animation.
    from Sequencer; select the grapic; select SCENE CONTROL; check PLAY RANGE; then i enter the last frame number into both the "start" and "stop" boxes. My animation runs 30 frames so i place 30 into both boxes and then go to export. that has been working for me. but have to remeber to turn off play range before actually airing the grapic.
    hope this helps
    S.
