  • 1.  Transition Logic between multiple full screen templates
    Posted 05-01-2017 19:24
    Hello all!
    I'm working on making an graphics package more operator freindly, and am struggling with getting the Transition Logic right for animating between different fullscreen graphics. There is a standard background in all the FS templates, but there is also different backgrounds to the text objects in the different templates. I wish to do three things: Be able to animate in and out when there is either no scene or a scene that is not a FS on air, this works as it should. Secondly when I change between the same FS template I want the text background to stay, and only the text to fade in and out. I have gotten this to work as well. But, the third option will be to animate between different full screen templates where the standard background does not move while the text and text backgrounds fade in and out. Thisis where I run into a problem. I can now see the right IN animation for the incoming FS do it's thing correctly, but the old FS does a full animate OUT on top of the incoming fullscreen. I have tried changing the rules' places in the list, but can not seem to find the right combination. When I turn on only one rule at a time it plays that rule correctly.
    I have 6 different Scene Directors (plus the standard empty one) IN/OUT, BTB IN/OUT for the same FS template and BTB IN/OUT for orher FS template.
    Will attach project sample.
    There are 8 different Full Screen templates, so I'm hoping to find a solution I can recreate on all the other templates.
    I have also tried to use the search option ("*FullS" in Scene Name) when making the rules, so I don't have to make rules based on Scene IDs, but without any luck. Any tips regarding this? All i know is the part from 14:00 in this tutorial: https://goo.gl/I8N5SG
    Thank you so much for any help and/or tips!
    https://www.dropbox.com/s/sfz05w1ler37sln/FS_TransitionLogic_Out_Issue.xpf?dl=0
    Best regards
    Oda
  • 2.  RE: Transition Logic between multiple full screen templates
    Posted 05-02-2017 02:20
  • 3.  RE: Transition Logic between multiple full screen templates
    Posted 05-03-2017 01:35
    One tip I have is to look at the XPression live log (you'll find it in the main menu) when playing with transition logic. When you take a new scene on air, the log will tell you which Rule it is running for both the incoming scene, and the outgoing scene. Note that both the incoming and outgoing evaluate their rules independently from each other and may choose a different rule as they use opposite definitions of this/other scene.
    I'll try to look through your project when I have some free time and see if I can see anything to help you.
  • 4.  RE: Transition Logic between multiple full screen templates
    Posted 05-03-2017 01:52
    See if this is what you want. https://transfer.rossvideo.com/f/9c76190faf215682
    Here are some of the changes I made..
    - The rule for the "back-to-back other scene" should have had the scene directors selected on the B2B tab instead of the In/Out tab.
    - The wild card should be FullS* not *FullS
    - The rule for the back to back should use the "Back To Back->Compare Scene Name" condition. This will check the scene name of the other scene that is on the same layer as the new scene being put on-air.
    Also, on the IN rule, if you enable the "Play out when incoming cuts", when you take another scene onto the same layer that has no transition logic at all defined, the fullscreen will still run its out animation before the other scene goes online. I didn't make this change in the project I sent you; but you can play with it to see if you like that option.
