  • 1.  Anchor Point for Animations
    Posted 01-24-2018 18:01
    Is there a way to set an anchor point on an object? I would like to animate a quad by scaling it up from the top left corner, but I have not found a solution to achieve this effect.
  • 2.  RE: Anchor Point for Animations
    Posted 01-24-2018 19:52
    In Xpression you can use the Pivots points for this. The way I do this... I usually turn on the move tool first so I can see the pivot points. If I have a quad that is 500 pixels in width, I divide it by 2, then enter -250 into the Pivot X field in the Transform tab. Now when you scale, it should scale from this new pivot position.
  • 3.  RE: Anchor Point for Animations
    Posted 01-25-2018 15:44
    You can also right-click on an object and use the pivot options to snap the pivot to the edges.
  • 4.  RE: Anchor Point for Animations
    Posted 01-26-2018 05:11
    OMG redmile... I didn't even know that... Thanks for posting!
