  • 1.  VB Scripting Scene Group
    Posted 08-20-2012 09:10
    hi there
    how do i get a scenegroup online with VB (ie .a crawl)
    the scene starts, but there comes no text with it.
    thanks
  • 2.  RE: VB Scripting Scene Group
    Posted 08-20-2012 11:39
    How do you do actually ?
    Do you use the xpSceneGroup Object and SetOnline Method ? Can we see a part of your code ?
    Don't you forget to use the Start() ?
    Vincent.
  • 3.  RE: VB Scripting Scene Group
    Posted 08-20-2012 13:34
    that's what i tried
    Dim sc as xp.SceneGroup
    Engine.Get SceneByName ("testcrawl", sc)
    sc.GetAnimControllerByName("wipein", ac)
    sc.SetOnline(0, -1, 0)
    ac.Play(0, 6)
  • 4.  RE: VB Scripting Scene Group
    Posted 08-20-2012 20:36
    I think Vincent is correct. You probably need the sc.Start()
    Take a look at this example:
    https://rossvideo.centraldesktop.com/p/eAAAAAAAATaiAAAAAFKYJo0
  • 5.  RE: VB Scripting Scene Group
    Posted 08-21-2012 12:24
    Yes, you were right .Start was it.
    Thanks a lot
    Linus
