  • 1.  Changing multiple object properties at once
    Posted 06-25-2017 20:00
    Hello, I noticed that in XPression you can Transform multiple objects at once if you shift click them all, but this doesn't seem to work on other properties. I was wondering if it's possible to change multiple Object's properties at once other than Transform features. For example, is it possible to change the Auto Squeeze max width size of 10 different text objects all at once?
    Thanks for any response,
    Jerry
  • 2.  RE: Changing multiple object properties at once
    Posted 06-26-2017 16:20
    If you have version 6.5, you could just use Visual Logic to achieve this by having a value block running into the auto squeeze max of each text object
