  • 1.  Copying projects in XPression Designer 3.60
    Posted 03-10-2013 17:49
    I'm currently using a project that I've built over a 3-day show, and now I need to take the project to a new truck for the next event. It looks like all the material is in one .xpf file: does that contain everything? Are there directories for fonts, graphic material, and scenes that I need to find?
  • 2.  RE: Copying projects in XPression Designer 3.60
    Posted 03-10-2013 17:57
    You shouldnt have to gather any directories XPression has an export process specifically for this scenario. Go to the file menu and select "export package". Follow the prompts to complete the process if you have files in your project directories that you are not using but want to keep, select the "unused files in project folders" option during the export.
    Once you have exported you will have created a .xpp file or "XPression Project Package" which will then have to be deployed on the new system. You can deploy this package as many times as you want so I would suggest doing a test deploy to make sure you have all of the assets you need.
    Cheers
    Andrew
  • 3.  RE: Copying projects in XPression Designer 3.60
    Posted 04-05-2013 11:50
    I've been experiencing the following:
    .xpp generated in Designer cannot be deployed in Prime, possibly vice versa as well.
    Is this a bug or intended?
    Thanks,
    alfrex
  • 4.  RE: Copying projects in XPression Designer 3.60
    Posted 04-05-2013 20:28
    There are certain features that are found in XPression Designer that are not supported in XPression Prime. Most notably 3D Models and Scripting.
