  • 1.  Elections Setup with ENPS
    Posted 10-04-2013 14:06
    I have a special election coming up soon and I need the best way to allow Xpression to pull information from ENPS and how to code it. I am currently on Xpression 4.1 build 2117. Thanks in advance!
  • 2.  RE: Elections Setup with ENPS
    Posted 10-07-2013 16:47
    Hi Lee,
    We are currently preparing a document that will help setup XPression with ENPS Stats, this should be ready for tomorrow.
    Do you have the XPression CII gateway software?
  • 3.  RE: Elections Setup with ENPS
    Posted 10-07-2013 18:24
    Yes we do have the CII gateway software? I have another question.
    Will the setup from the document you are preparing for me work on our Prime as well? I have a unique setup in a second control room and I need to be able to tie it into the same ENPS Data. I know it has DataLink but it doesn't have the CII gateway installed. Other than the CII gateway will the Prime need any other software to bring it into the information loop?
  • 4.  RE: Elections Setup with ENPS
    Posted 10-07-2013 18:26
    The Prime will only require it's own CII Gateway to receive the information.
  • 5.  RE: Elections Setup with ENPS
    Posted 10-07-2013 18:28
    Thanks Garner!
  • 6.  RE: Elections Setup with ENPS
    Posted 10-09-2013 20:15
    If that document is ready, could you forward it to me as well? Thanks Garner!
  • 7.  RE: Elections Setup with ENPS
    Posted 10-15-2013 10:29
    Lee & Rob,
    I have sent you the package. Please let me know if you have any questions.
