the "Keyboard / GPI Mapping" menu provides the definition of shortcuts. This seems to be limited to the number of "hardware keys" on a PC keyboard rather than the 136,755 charcters that a UNICODE table can hold. If this sounds rediculous, just keep in mind that many installed Windows programs together utilize a huge amount of shortcuts an keystroke combinations that I don't want to interfere with XPression shortcuts under no circumstance.
I would like to make use of the many exotic UNICODE characters that will never be used in order to learn them for example on a X-Keys keyboard mapping. This would result in hundreds of unique buttons that would never interfere with any of my main keyboards keystrokes. I kow there are e. g. the F13 to F24 keys - but on one hand this is also not enough for me and on the other hand many of those keys are already in use by XPressions Global shortcuts, right?
I tried it with some exotic UNICODE characters, but the keyboard shortcut field is just showing an "M" for all those characters and does not interpret them the way it would work.
Any suggestions?
With best regards
