  • 1.  Xpression Datalinq server
    Posted 04-24-2018 18:37
    Hi, I've reinstall Xpression Designer on a new pc. When I try to connect to my database I'm receiving this message (when i'm testing the connection) :
    "‹Failure:Provider cannot be found. It may not be properly installed.
    Any ideas?
  • 2.  RE: Xpression Datalinq server
    Posted 04-26-2018 14:20
    Are you using .xlsx file?
    Most likely you need to install the 32bit excel drivers if you are.
  • 3.  RE: Xpression Datalinq server
    Posted 04-26-2018 14:21
    I've try on a others computer and it's working. Thx.
