  • 1.  Will 'Wake On Lan' work on Prime machine?
    Posted 10-03-2013 20:42
    Can I make Wake on LAN work on our Prime Unit? I have not had any luck yet. I have check marked those settings in the network card settings and looked in the Bios for setting but did not see anything that jumped out at me. We are using the #2 network port in the machine. Is this possible? We want to be able to remote power the machine and log in remotely to do some basic setups on the machine before a tech shows up to run a show.
    Grant
  • 2.  RE: Will 'Wake On Lan' work on Prime machine?
    Posted 10-07-2013 18:12
    Hi Grant,
    Which NVidia card do you have installed on your unit?
    GTX 560ti or 660ti? (We can determine which motherboard you have with this information)
    Garner
  • 3.  RE: Will 'Wake On Lan' work on Prime machine?
    Posted 10-08-2013 16:20
    We have the GTX 560Ti board installed in our Prime system.
  • 4.  RE: Will 'Wake On Lan' work on Prime machine?
    Posted 10-23-2013 22:25
    Any ideas?
  • 5.  RE: Will 'Wake On Lan' work on Prime machine?
    Posted 10-30-2013 04:05
    Hi Grant,
    Your XPression is running with an ASUS P6X58-E WS motherboard.
    I haven't been able to investigate how to enable wake on LAN with this motherboard.
  • 6.  RE: Will 'Wake On Lan' work on Prime machine?
    Posted 10-31-2013 21:24
    Thanks! I got it working after a quick search on that model of motherboard.
