  • 1.  Description Field In Abstract?
    Posted 10-06-2017 18:35
    Is there a way to add the "Description" field (in the NRCS plugin) to the MOS abstract seen in OverDrive? It seems like it would be an ideal place to put timing notes for the APC Operator.
  • 2.  RE: Description Field In Abstract?
    Posted 10-06-2017 18:46
    Yup! Change the XPression MOS abstract:
    https://transfer.rossvideo.com/f/f45415fd6a8859f2
    This will only change newly created XPression MOS Objects, it won't change old ones.
  • 3.  RE: Description Field In Abstract?
    Posted 10-06-2017 20:32
    Awesome. It's not on the list, but I assume @DESCRIPTION@ would show the Description field?
