Hey all,
I've just received an after effects file to be imported into xpression for a show. I've tried to render one or two compositions in a few different formats, it needs to hold a alpha channel.
On a standard playback within quicktime it looks completely fine, but as soon as I attempt to import it into xpression it seems to have some weird artifacting around the actual animation.
How it should look:
http://i.imgur.com/ma7TkAs.png
How it appears within xpression:
http://i.imgur.com/0WSLK3Q.png
My usual workflow is to render it as a Quicktime MOV w/ PNG, then I will import it into Ross' Xpression Video Coder & export it through that (without changing anything within the alpha channel section). I then import it into Xpression as per usual. I've been doing this workflow for almost a year and a half so it's very odd that I'm having this issue!
If you could help then that'd be great.
