  • 1.  Update TextObject linked to DataLinq without SceneGroupObject
    Posted 03-20-2014 21:02
    Hi All,
    How can I Update TextObject text in a scence, linked to DataLinq without SceneGroupObject
    Also When we create crawl, I want to place a text on SceneGroupObject which is linked to Datalinq, and it is updated using increments.
  • 2.  RE: Update TextObject linked to DataLinq without SceneGroupObject
    Posted 03-21-2014 20:35
    You can connect any text object to Datalinq, it does not need to be an object in a scenegroup.
    Select Text Object > Object Inspector > Data Source > Datalinq
    You can download a rough document that covers how to set up an RSS data source and step through the fields in an XPression crawl.
    Stepping through an RSS feed
  • 3.  RE: Update TextObject linked to DataLinq without SceneGroupObject
    Posted 03-25-2014 00:54
    Yeah, Linking and stepping through datalinq data in a SceneGroup is fine, but I want to achieve same thing without using a SceneGroup or without Crawl/Roll effect.
    For Example, I have a animation with a textObject linked to a text file with few lines through datalinq. The text file may contain any number of lines, we don't know in advance how many lines will this text file contains. I want to step through those lines without using Crawl/Roll effect [SceneGroupObject].
  • 4.  RE: Update TextObject linked to DataLinq without SceneGroupObject
    Posted 03-25-2014 16:24
    I would take a look at these videos about XPression Datalinq:
    http://xpression.rossvideo.com/videos/
    I believe that 'Data Pages' will be the one you want.
