Ok, so I'm having a really weird issue, and it may be because I have the wrong type of serial cable. I've connected the Allsport CG to the Xpression box, and have fired up Datalinq, and it's saying it's connected to the Allsport, but it's not getting any of the info.
However, the Allsport is showing the score and clock correctly on its LCD panel. So I know the scoreboard is connected to it, it's just not connecting to the Xpression Datalinq.
The question I have is, should I be using a 9-pin dual-female cable? I'm using a 9-pin m/f cable, and that means that the female connection is going to the Xpression as that's the only connector on the box, and the male connector is going to the CONTROL port on the Allsport CG, instead of the port labelled DATA.
Is this cable the problem? And if so, what is Xpression "seeing" that is making the Datalinq think it's correctly connected?
Any and all help is much appreciated. I'm now in the middle of double-header basketball and we're having to hand-drive the scoreboard.
