Is there a way I can renumber a given scene using script/visual logic so that when we reach 4th quarter, or if a scene has already been aired the ID will change? We use NBA DTVI for stats and I have both a popup and a lower third use for several of the stats. These stats push to a pre-determined scene number. Once used, I would like to renumber a different scene with the necessary scene ID to push data to this scene. Make sense? Thanks
I know that DTVI can be edited but that's outside my job description.
