  • 1.  Scripting Visibility by Integer
    Posted 02-06-2014 17:43
    We have two scripts running on our stocks full screens, both intending to do the same thing, but written by two different people. As we know, everyone has their own style of writing code, but going through these, they should both work fine.
    However, Version A will return a false 0 when the number is extremely close to zero (-0.24 through 0.24), and it incorrectly changes the visibility of one of our scenes to 0.
    Version B works correctly.
    My questions is not which one is "right," but rather why Version A is not working correctly, as it should be just fine (and in my opinion, is a cleaner code)
    Version A
    dim change as xpTextObject
    dim arrow as xpBaseObject
    dim redmat as xpMaterial
    dim gremat as xpMaterial
    dim changeval as double
    dim i as integer
    Engine.GetMaterialByName("Arrow - Red", redmat)
    Engine.GetMaterialByName("Arrow - Green", gremat)
    for i = 1 to 3
    Self.GetObjectByName("Change " & i, change)
    Self.GetObjectByName("Arrow " & i, arrow)
    changeval=Cint(change.Text)
    if changeval (is less than) 0 then
    arrow.Visible = True
    arrow.SetMaterial(0, redmat)
    arrow.SetMaterial(1, redmat)
    arrow.ScaleY = -(arrow.ScaleY)
    elseif changeval (is greater than) 0 then
    arrow.SetMaterial(0, gremat)
    arrow.SetMaterial(1, gremat)
    arrow.ScaleY = Math.Abs(Arrow.ScaleY)
    elseif changeval = 0 then
    arrow.visible = False
    end if
    next i
    Version B
    dim CHNG as xpTextObject
    dim Arrow as xpBaseObject
    dim RedMat as xpMaterial
    dim GreMat as xpMaterial
    dim CHNGVAL as Double
    dim i as Integer
    Engine.GetMaterialByName("Arrow - Red", RedMat)
    Engine.GetMaterialByName("Arrow - Green", GreMat)
    for i = 1 to 4
    Self.GetObjectByName("Change " & i, CHNG)
    Self.GetObjectByName("Arrow " & i, Arrow)
    CHNGVAL = CHNG.Text
    If CHNGVAL (is less than) 0 then
    Arrow.SetMaterial(0, RedMat)
    Arrow.SetMaterial(1, RedMat)
    Arrow.ScaleY = -(Arrow.ScaleY)
    End If
    If CHNGVAL (is greater than) 0 then
    Arrow.SetMaterial(0, GreMat)
    Arrow.SetMaterial(1, GreMat)
    Arrow.ScaleY = Math.Abs(Arrow.ScaleY)
    End If
    If CHNGVAL = 0 then
    Arrow.Alpha = 0
    End If
    next i
    EDIT: replaced the actual greater than and less than symbols with (is greater/less than) in order to not confuse the forum.
  • 2.  RE: Scripting Visibility by Integer
    Posted 02-06-2014 18:00
    Hi Dan,
    The function CInt() will convert a text string to an Integer value. An integer, by definition, is a whole number, and therefore any decimal points will be truncated. It essentially rounds your value to the nearest whole number.
    CSng() will convert to text and preserve the decimal places.
    Try just replacing CInt with CSng
  • 3.  RE: Scripting Visibility by Integer
    Posted 02-06-2014 19:49
    The input values (fyi) are always truncated to two decimal points (x.xx). Is there any particular reason either of these scripts should use doubles, then?
    I get the feeling I should just rewrite this all to singles with CSng.
    EDIT: Also, I like Version A's use of elseif instead of opening up a new if/end if, so I'm planning on re-writing this script anyway. Just couldn't see why A was misbehaving. Cint/Csng makes perfect sense now that you point it out.
