This is usually because the AVI is encoded at the wrong framerate or the XPression Project is in the wrong framerate.
Double check the framerate you have selected in the XPression Video Coder. (Video Coder > Output Format > Framerate)
Double check the framerate you set in your XPression Project (XPression > Project > Convert Project Mode > Editing Mode)
