  • 1.  Create a Combobox linking tot materials/images
    Posted 06-28-2017 14:33
    Hey There,
    Is it possible to make a script in the designer (scripting of visual) which create a combobox in the sequenser,
    where you can select a material/image?
    No linking to a txt/xml is needed.
    Greets
  • 2.  RE: Create a Combobox linking tot materials/images
    Posted 06-28-2017 19:19
    You could fudge it without having to use a script. Ex: My L3 has an option for Facebook, Twitter or Instagram Logos. So Create a 0% opacity text field for the combo box, then tie the image field to that text field. Pretty simple really.
    So in this example,, the name on the L3 dictates the Handle and logo
  • 3.  RE: Create a Combobox linking tot materials/images
    Posted 06-28-2017 22:43
    Instead of setting it to 0%, you can just turn off its visibility.
