  • 1.  copy/paste Datalinqs
    Posted 03-26-2017 04:58
    Was watching a few videos just to see if I could come across some tips/tricks...and sure enough saw that you can copy/paste datalinq fields ( https://youtu.be/R-yj6e9eW4w?t=2m8s ) ...however, when I tried it in one of my ESPN packages the copy/paste window never appears. Is there a setting to enable this?
  • 2.  RE: copy/paste Datalinqs
    Posted 03-27-2017 17:13
    What version of XPression are you using? It should not be related to any particular package you have loaded; and there is no setting to enable this.
    If you start xpression with a blank package, and add a new text object, you are unable to rightclick in the datalinq field to select copy/paste?
  • 3.  RE: copy/paste Datalinqs
    Posted 03-28-2017 20:33
    v6.7 build 3722...I can do it in a blank project yes (seems to be in edit mode only though, not in sequencer) however, in the (out-of-house) package I have I can't do this in either layout or sequencer mode...
  • 4.  RE: copy/paste Datalinqs
    Posted 03-30-2017 17:47
    I think we'll need a copy of the project you're having issues with to see if it happens to us as well.
