This is odd. I have a very simple side slab element which needs to be able to contain any sort of information as a sentence or paragraph. Easy enough, but once i turn word wrap on and start entering text, I get crash dialogues. The message is EAccessViolation at address 00ABA9EC in module 'XPression.exe' Read address of 00000008.
Not really certain how to combat this, or if it is a known issue. I tried to send the crash report (twice) and the send failed as well.
While on the topic, assuming I can find a fix or work-around.. is there a way to put a 'Max Height' on this block of text so that it cannot vertically exceed the boundaries of the graphic?
- Willie
