  • 1.  Using the API to change a published image (Sequence)
    Posted 03-02-2017 13:47
    Using the API I have loaded a scene (with several published items)
    I have stored the scene in my sequence.
    The first published item is an image (Material)
    Now I want to update the image.
    I load the first Published Object in a xpPublishedObject.
    Then I can set the Material with SetPropertyMaterial
    I have to pass an existing Xpression Material.
    If I do that (and change the image inside it), other places where that material is used will change too, I guess.
    So maybe I will have to create a new Material for the occasion? If I do that, I will end up with many orphan materials.
    Is there a better way?
    Regards,
    Barend
  • 2.  RE: Using the API to change a published image (Sequence)
    Posted 03-02-2017 14:12
    You should be able to call SetPropertyString and pass a filename to an image on disk.
