  • 1.  Animated Stroke
    Posted 07-06-2018 19:37
    I am tasked with doing an animation of a partial stroke outlining a quad. In Cinema 4D or After Effects, this is child's play (animated Sweep in the former, or a Stroke effect on a Mask in the latter), but in XPression, the best I have been able to conjure up is a series of thin quads, re-positioned anchor points, scaling, position, and masking for each side, with carefully orchestrated timings for each side, so that the illusion holds. This is a VERY cumbersome and onerous process, and will become a bottle-neck in this package as every element uses it.
    So, before I get too far down this rabbit hole, I thought I would ask if there are others who have done this sort of thing, and maybe found an easier, more scaleable, sustainable approach.
    Thanks in advance
  • 2.  RE: Animated Stroke
    Posted 07-07-2018 01:04
    I'm honestly thinking at this point, it's just easier to crank it out in AE, export it as a movie, and overlay it atop the elements in XPression... It would be cool though to have animated strokes in XP...
  • 3.  RE: Animated Stroke
    Posted 07-09-2018 14:46
    It would be easier to create this in AE and then drop it in the XPN scene.
  • 4.  RE: Animated Stroke
    Posted 07-09-2018 19:39
    I once executed a highlight of a rectangular stroke (and highlights of several other still layers) using masks and the continuous animation capability. Using this approach, I was able to rebuild a look that would have been two or three layers of video otherwise. It seemed to be less costly on resources.
  • 5.  RE: Animated Stroke
    Posted 07-12-2018 21:43
    You achieve this effect by rendering the stroke outline as a mask, for each side in AE.
    Then you can import it, have each mask mask only one side of your rectangle.
    If you do your timings right, you can stretch w/e expanding portion of your rect. The velocity should be consistent as long as your clips are in the right order in Scene Director.
    Am doing this for a show currently.
  • 6.  RE: Animated Stroke
    Posted 07-12-2018 21:46
    Thanks, but I have found it far easier to just render the animated strokes for the element in question out of AE as a single video, which I apply as a texture on a quad, its fast to setup, and even faster to render, so if a change is needed, the swap is easy to execute. I'd prefer to not have to choreograph multiple overlapping animations one by one.
