[SOLVED] Continued crawl example
Elias Giannopoulos
Elias Giannopoulos07-22-2013 17:57
Elias Giannopoulos
Elias Giannopoulos07-26-2013 11:54
Elias Giannopoulos
Elias Giannopoulos07-31-2013 19:29
Marcelo Procyk
Marcelo Procyk11-12-2013 13:39
Marcelo Procyk
Marcelo Procyk11-12-2013 13:43
  • 1.  [SOLVED] Continued crawl example
    Posted 07-22-2013 09:26
    Im try to play a crawl that runs for ever with VB6 & API.
    I need to add new content (text data) at the end of the crawl
    Actualy is a Sports Match results, that never ends, and new data comes every 10 seconds.
    So how can I add new text at the end, and how can I remove oldets entry from the begining of the crawl?
    Is any sample code and a logic of add/remove content, because the manual has a simple crawl/roll sample?
    Thanks in advance for your help
    Elias
  • 2.  RE: [SOLVED] Continued crawl example
    Posted 07-22-2013 11:17
    Hi Elias,
    I can probably fic you up with an example but I can only send it tonight when I get home.
    But to quickly explain the principle. There are two ways that you could do this. You could create a scenegroup and add new scenes to that scenegroup, but I never got that working properly.
    So what I've been using is a single scene which has 5 textobjects which I animate across the screen and I simply replace the contents of the textboxes. This way I also get more control over the crawl.
    Kenneth
  • 3.  RE: [SOLVED] Continued crawl example
    Posted 07-22-2013 12:57
    Dear Kenneth,
    thanks for your answer.
    Im wating for your example code.
    I'll buy you a beer for your valueable help.
  • 4.  RE: [SOLVED] Continued crawl example
    Posted 07-22-2013 17:46
  • 5.  RE: [SOLVED] Continued crawl example
    Posted 07-22-2013 17:57
  • 6.  RE: [SOLVED] Continued crawl example
    Posted 07-26-2013 11:54
  • 7.  RE: [SOLVED] Continued crawl example
    Posted 07-26-2013 12:30
    Hi Elias,
    I haven't forgotten about you, I just have to clean up the code to make it a bit more readable and add some comments in English.
    Hold tight :-)
    Kenneth
  • 8.  RE: [SOLVED] Continued crawl example
    Posted 07-31-2013 18:15
    Hi Elias,
    You can find a demo here: http://pastelink.me/dl/23c10b
    I should mention that I didn't had the chance to test it as my XPressions are in production somewhere else and I only have my BlueBox-dongle with me for now.
    There's also no XPression project included but that's easy to make, just create a project, add a scene called "Crawl", add 5 textobjects called "Text1" through "Text5" and also add 5 animation controllers called "AnimationController1" through "AnimationController5" and I think it should work, but don't shoot me if it doesn't ;-)
    Good luck!
  • 9.  RE: [SOLVED] Continued crawl example
    Posted 07-31-2013 19:29
    It works.
    Thanks man.
    Your rock!!
  • 10.  RE: [SOLVED] Continued crawl example
    Posted 08-01-2013 00:32
    Oh it does? Wow, sometimes I even surprise myself :-)
    One more remark about the code I sent you. I just realized that I update the contents of the textfield at the moment it went off the screen. So if you have long messages, it could take a while before that textfield goes back into the crawl. So it might be better to change the update to the moment before you start the animation. Just to be sure to have the latest information.
    Good luck with your project!
  • 11.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 13:27
    Elias,
    You have an example of how you solved the crawl using API xpression?
    regards
  • 12.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 13:35
    Hi Marcelo,
    Yes I have. Do you familiar with VisulBasic 6?
  • 13.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 13:39
    yes !
  • 14.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 13:41
    ok then. give me a day to extract the ContinuedCrawl code. I will inform you
  • 15.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 13:43
    thank you so much !
  • 16.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 14:23
    Here is the sample (Many thanks to Kenneth for his valuable help)
    the zip includes VB6 code & xpp project
    Load the project with xpression before run the vb code.
    https://www.wetransfer.com/downloads/dc4b7722b87bdd2ab8946c90b868107920131112141519/5db6b713a7464b43e5bac2589c08576b20131112141519/2fc847
  • 17.  RE: [SOLVED] Continued crawl example
    Posted 11-12-2013 14:34
    Thank you, Kenneth and Elias, for your contribution in the forum.
  • 18.  RE: [SOLVED] Continued crawl example
    Posted 06-08-2018 20:47
    Elias,
    Take a look at this sample example:
    https://rossvideo.centraldesktop.com/p/eAAAAAAAABXGAAAAAGNaWO4
    Could you share this again pls...
