  • 1.  Audio files
    Posted 08-24-2017 21:21
    Is there a way to shorten or fade out a wav file? The sound effects for our show seem to loop and we cannot figure out why. I have imported the audio file and dropped in in the scene director. When playing out it loops at the end of the sound effect. Or is this something that has to be fixed on the actual wav file?
  • 2.  RE: Audio files
    Posted 08-25-2017 13:19
    You can record keyframes on the audio track in the scene director. There is a little arrow to expand the audio track and a little red "record" button that marks a keyframe. You can then adjust the volume of the audio track to fade it out. However, it is far easier to actually edit the wav file so if you need to use it in multiple scenes you don't have to keep adjusting the scene directors.
    There is a free WAV editing application called Audacity that works very well.
