  • 1.  Please tell me there is a way to mute audio on clips inside the edit mode for Ross Expression Video Servers..
    Posted 07-05-2017 14:09
    We're running 2 ross video servers and there is a request from the audio guy to mute the audio at the source for several of our clips. When i go to edit the clip there isn't a mute option. However, after a lot of searching I found that I could change the length of the audio clip in edit mode but it doesn't save. even when i try to export it as a new clip it retains the original audio.
  • 2.  RE: Please tell me there is a way to mute audio on clips inside the edit mode for Ross Expression Video Servers..
    Posted 07-05-2017 16:26
    I usually just add a key frame on the track in the scene director, and set the level to 0. But that's just on Xpression.
  • 3.  RE: Please tell me there is a way to mute audio on clips inside the edit mode for Ross Expression Video Servers..
    Posted 07-05-2017 16:35
    I think he's using XPression Clips, not XPression Studio/Prime.
    I'm not sure there is a way to mute a clip from the clip database...
    You tried exporting out of the Clip Editor back into the Clip Store with audio set to ?
