I made a lower third animation with 2 scene directors. Effect In (in animation) and Effect Out (out animation). The animation in is fine. I copied the animation controller with all the keyframes for the text in to the Effect out scene director and made it reverse direction by right clicking on the anim. cont. and adding the reverse direction option. This has worked for me in the past, but for some reason it is cutting of when I use the "Take Offline" button in the Sequence. The only difference is that I am using a video file for the box behind the text. Any suggestions?
