  • 1.  Is it possible to use Datalinq in Tick-it?
    Posted 06-03-2017 06:17
    I want to change video material using Datalinq and Excel. But not success yet.
    It is work in XPression Designer but when I publish the project to project server and using it to Tick-it then video not showing.
    Is it possible change video from Excel using Datalinq in Tick-it?
    Please help.
  • 2.  RE: Is it possible to use Datalinq in Tick-it?
    Posted 06-07-2017 15:47
    Yes it is. But if Tick-it is trying to control the same object as you have Datalinq'd then Tick-it will override Datalinq. Have you given Tick-it control of the same object you have Datalinq'd?
  • 3.  RE: Is it possible to use Datalinq in Tick-it?
    Posted 06-08-2017 14:20
    No I have no Tick-it control of the Datalinq object.
    Can you check my scene from the link below please.
    https://drive.google.com/open?id=0B6...U9mLVA4NC1PQ0U
