  • 1.  Expression Software Version
    Posted 09-15-2012 11:48
    Is it correct the Expression software only package ( ie no hardware) offered with Carbonite supports only still images and not animations?
  • 2.  RE: Expression Software Version
    Posted 09-17-2012 20:34
    Hello Peter,
    XPression LiveCG, the software that ships with the Carbonite packages populates the MediaStore of the Carbonite switcher via FTP.
    It will populate the MediaStore with a single frame, so animations cannot be played via this connection.
    Keep in mind that all the Switcher/XPression packages come with the option of upgrading to XPression Prime. The Prime software/hardware supports a single channel SDI framebuffer output board. Which will support animations & video.
