  • 1.  Xpression Video Coder Issue
    Posted 02-01-2017 15:44
    After upgrading our MACs to El Capitan I am no longer able to use the Animation Codec to out put files for transcoding in the Xpression Video Coder.
    When using Apple Motion or Final Cut Pro X do I still need to use the Video Coder to get elements into Xpression? Either way what codec should I use?
  • 2.  RE: Xpression Video Coder Issue
    Posted 02-01-2017 17:00
    Issue solved..used the Pro Res 422 HQ codec. Works like a charm!
