  • 1.  Update Text Transition Flash-Frames Previous Item
    Posted 04-06-2018 19:18
    I'm building a topic bar for a show in Xpression Studio 7.0 (Build 3794), and have successfully made in and out transitions. I then built animations with transition logic for when text updates in the same scene back to back. I seem to have set that up properly as the proper animation controllers run, however, at the end of the update animations, the first frame of the previous text flashes on screen for about 1 frame. Both in and out scene directors are clipped to the exact same length, The same does not happen when I take the scene online or offline, only on the text update.
    Any idea as to why this might be happening?
    Thanks in advance!
  • 2.  RE: Update Text Transition Flash-Frames Previous Item
    Posted 04-07-2018 14:49
    There's is a very good video here : https://www.youtube.com/watch?v=8h_qRYtICQw
    at 7'40 it talks about setting "Default Frame Marker" on scene directors to avoid some "pop-off visibility" : maybe it will help solve your problem ?
  • 3.  RE: Update Text Transition Flash-Frames Previous Item
    Posted 04-07-2018 16:17
    If you can't figure it out; we need you to share a sample so we can show you where the mistake is.
  • 4.  RE: Update Text Transition Flash-Frames Previous Item
    Posted 04-09-2018 13:07
    That video mentioned making a blank scene director to make the default. I hadn't done that, tried it, and all seems to be working properly now. Thanks for the help!
